1990 ASD Relay Location
Old Aug 9, 2010 | 10:36 AM
sacgun1's Avatar
sacgun1
Default 1990 ASD Relay Location
I have a 1990 3.9 4x4 Dakota. I don't think the ASD relay location and splice is in the same location for 92+ as for 91- trucks. That is there's no power distribution or fuse box behind the battery. The fuse panel is under the drivers side dash.
My truck cranks but won't start. I changed the coil but there's no voltage to the coil, no spark out of the coil wire and I'm not hearing the fuel pump.
Old Aug 9, 2010 | 12:11 PM
Chris0908's Avatar
Chris0908
Please refer to the FAQ Section to answer this question. There is a whole area on it, and shows and marks where it would be.
Old Aug 9, 2010 | 12:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the earlier models may be different. And the splice may not be your problem. But you can still check for power at the ASD relay and fuel pump relay. Get a volt meter out and check.
Old Aug 9, 2010 | 01:29 PM
sacgun1's Avatar
sacgun1
I checked the FAQ section and it doesn't show the location of the relays on a 1990. It shows 1992-1996. There is no PDC box behind the battery.
Old Aug 27, 2012 | 05:30 PM
ktmjeff's Avatar
ktmjeff
New Member
hey, were is the fuel pump relay located on a 1990 dakota?
Old Aug 27, 2012 | 08:33 PM
JR318's Avatar
JR318
Next to the ASD relay lol. If someone can find one or the othere they will find both. Not trying to be a smart@ss even though ut kinda sounds like it.
Old Aug 28, 2012 | 01:53 AM
Crazy4x4RT's Avatar
Crazy4x4RT
In the FAQ. https://dodgeforum.com/forum/1st-gen...e-manuals.html
