Front brakes...
Seemingly (unless you folks advise its all wrong!) good guide:
http://automechs.com/video/76/1999-D...ake-and-Rotors
Nice to see you again, and THANKS for that tip on the build sheet!
@ Crazy4x4RT - Please forgive my being slow sometimes, but how? I clicked on FAQ above, and that lead me to a search. I put in "service manual" and it did not like that too much!
edit: Ohhhhhhh. The sticky labeled FAQ as opposed to the FAQ link in the navigation bar.... Now I get it!
edit: And your post in the 1st Gen section entitled "Factory Service Manual"...
edit: One last edit for now - Thank-you!
Oh that was not pretty-
The left side went fine, but when it came to the right side - front - the top bolt snapped off in the frame that holds the caliper, though the bottom removed without problem.
What the heck do I do now??? (Please!)
You mean the caliper bolt sheared off? I suspect... it'll need to be drilled out if that's the case.
Is this my answer?:
http://www.autozone.com/autozone/par...43_0_6828_2805
If so, do I drill out just the core section of the bolt or drill out the threads also?
I believe you'll want to drill out the core section of the bolt.
I would think you want to avoid drilling out the threads too, as this will cause a gap to which even the new pin can't fix.
I could be wrong so don't quote me, I'm no expert.
Anyone else want to weigh in and assist?
Used to live in SE Michigan - you are on the way between there and Toronto, aren't you? Beautiful country.
Suspect I will wait before doing any damage, get the bolt from Autozone, then see what I need do to make the darned thing go in and not come dropping out, though if there are any others out there that have been down this path, I would appreciate any warnings!
