V6 aftermarket camshafts?
Old Aug 22, 2010 | 04:25 PM
Lirra's Avatar
Lirra
Default V6 aftermarket camshafts?
Is it still possible to get performance camshafts for the 3.9 engine?
Old Aug 22, 2010 | 05:41 PM
95_318SLT's Avatar
95_318SLT
Yes. Check here...
http://www.hughesengines.com/Index/index.php
There may be other places that have some as well, but thats the only one I know of off the top of my head.
Old Aug 28, 2010 | 02:38 PM
Lirra's Avatar
Lirra
Thanks! Does the LA and Magnum engines share the same camshafts?
Old Aug 28, 2010 | 03:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No they are different.
Old Aug 28, 2010 | 03:57 PM
Lirra's Avatar
Lirra
Uh-oh, I think they only offer camshafts for the Magnum...
Old Aug 28, 2010 | 09:37 PM
bill55az's Avatar
bill55az
I have a "purple" cam for the older v6, with lifters, new in the box....MP part number is p4452810....
Old Aug 28, 2010 | 09:56 PM
bill55az's Avatar
bill55az
If it is your intent to improve your current engine, you will need a better intake manifold. I advise getting an 88-90 TBI intake and having the top machined to take a larger 2 barrel carb, like what was found on the 360 and 400 engines..
The 87 BBD carb bolt pattern is too close to the Holley to allow just buying an adapter.
I put the bigger 2bbl carb and a 360 intake manifold on a 318 once, dropping 2 sizes for the jets, and it ran very smooth. I only lost 1 mpg in mileage...
With a purple cam, you will need an improved intake and exhaust system to get the best performance gain.
Old Aug 29, 2010 | 05:48 AM
Lirra's Avatar
Lirra
I think my Dakota really is a '88, as it has the TBI. I've been in contact with thefastman.com, and will probably buy one of his TB's. I will also get the Edelbrock headers from Hughes Engines.
bill55az: What are the specs on that camshaft?
Old Aug 29, 2010 | 09:45 AM
bill55az's Avatar
bill55az
flat tappet camshaft-p4452810
-hydr. lift .430/.450
-dur. 260/268
-overlap 44
-centerline-110
I won't be using it, so it is available....$120 shipped (lower 48)
Old Aug 29, 2010 | 09:47 AM
Lirra's Avatar
Lirra
Thanks. Do you know the specs on the stock camshaft as well?
