Oil Pressure!!!
Old Sep 5, 2010 | 12:32 AM
will4557's Avatar
will4557
Default Oil Pressure!!!
Sometimes my oil pressure runs real good and sometimes it runs low(while driving down the road). I have already put a new oil pressure switch on it and that didnt do anything. I was wondering if my oil pump is fixin to go out and if I need to go ahead and change it? Also how hard is it to get the oil pan off? Do I have to take anything off it to get pan off so I can change my pump?
Old Sep 5, 2010 | 02:01 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It is typical of higher mileage engines to run low oil pressure. One guess I always had for the low psi is a bad ground to the sensor. But I'm not 100% on that.
It is best to get a mechanical gauge and verify the pressure.
Old Sep 5, 2010 | 03:34 PM
luthoro's Avatar
luthoro
My truck has 203k miles on it, and my oil pressure is great. Mileage doesn't matter, its how well it was maintained.
Old Sep 5, 2010 | 03:39 PM
97dodge4x4's Avatar
97dodge4x4
i think in a haynes manual it tells you the lowest oil pressure allowable, and it was like 8 psi or sompthing like that so as long as u have oil pressure i think u should be fine, what does ur truck run at idle all warmed up? mine runs at about 20-25psi
Old Sep 5, 2010 | 05:55 PM
will4557's Avatar
will4557
It stays between the tolerable lines. Most of the time it runs real good(above half way on gauge), but every once in a while it will go to the low side. It was just something I was wondering about. I will check the ground to the switch and see about that. Thanks for all the replys!!!
Old Sep 5, 2010 | 07:22 PM
sammatthews2007's Avatar
sammatthews2007
This happens to me too. I notice it happening when I stop my truck, maybe the oil's traveled a bit to the front (away from the sensor).
