My transmission fluid/filter/pan gasket change thread
Old Jun 23, 2014 | 12:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by Jnew28
I have a 1992 Dakota with a 5.2 4wd auto trans..was able to remove all bolts from trans pan, but running into a big problem trying to get it off got it where it came off but no why to get it out with the exhaust being so tight against it..is there a simple way that I just don't know? Any suggestions? Would help thanks just trying to avoid taking the exhaust off .
Make sure the dipstick is pulled out first, next remove the transmission mount and jack up the transmission it might get you some clearance. Also don't be scared to start a new thread.
