replacing E.G.R.
Old Sep 16, 2010 | 06:56 PM
bigblackdakota's Avatar
bigblackdakota
Default replacing E.G.R.
Do you guys think it's worth it to replace the egr if the truck throws up the code?
Old Sep 16, 2010 | 09:32 PM
9652dakota's Avatar
9652dakota
depends on if you like your truck to have broken parts.
Old Sep 16, 2010 | 09:33 PM
LO 619's Avatar
LO 619
I would try cleaning it out first, it's probably just clogged. Don't waste your money on a $50+ part if you don't have to, buy a new egr gasket and some carb cleaner and see if that solves your problem.
Old Sep 16, 2010 | 09:51 PM
bigblackdakota
Good Advice, I'll give that a shot...will the trouble code erase itself if everything works out??
Old Sep 16, 2010 | 09:55 PM
9652dakota's Avatar
9652dakota
it will go stored in ten good trips or you can just unhook the batt and short the cables together(while unhooked) to wipe it out and start off new.
Old Sep 17, 2010 | 08:56 AM
bigblackdakota
my engine light isn't on but when i check the codes i get 4 of them, does this mean nothing is wrong at all and they all have been fixed?
