Tire Size
Old Sep 19, 2010 | 11:14 PM
asosnoff's Avatar
asosnoff
Default Tire Size
I have 92 Dakota with a 318, 4 wd. What is the largest tire I can use that will not rub with no modifications.
Old Sep 20, 2010 | 12:07 PM
Deerkiller9991's Avatar
Deerkiller9991
I have a 2wd and i have 225s in front and 30x9.5 (a lil bigger than 235s) in back on 15s
Old Sep 20, 2010 | 01:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a copy and paste from our FAQ2.
What can I fit on my 4x4?
Stock...29 -30 inches
1-2 inches... 31s
2-4 inches... 33s
4-5 inches... 35s
Check http://www.4wheeloffroad.com/techart...ide/index.html
What can I fit on my 2wd?
Stock... 235/75r15
1-2 inches... 30s
2-4 inches... 31s
If you crank up your torsion bars you can get 1in or so of lift for free.
Old Sep 20, 2010 | 07:40 PM
asosnoff's Avatar
asosnoff
so I can put on up to a 30" with no lift and no rubbing if I understand correctly
Old Sep 20, 2010 | 09:23 PM
Hahns5.2's Avatar
Hahns5.2
31x10.50s didn't rub on my truck with the stock wheels, my current wheels have less backspace so they stick out further and the fronts rub the bottom corner of the wheel opening when turning.
Old Sep 21, 2010 | 12:07 PM
Deerkiller9991
IMO you could get a away with 30's. but you could probably put 31's out back. But I would listen to crazy4x4, he's smart man
