Power Loss?
Old Sep 24, 2010 | 11:52 AM
Az93DKota's Avatar
Az93DKota
Default Power Loss?
Its been a while since Ive been on DF due to work keeping me busy. I started using my truck as a DD. I noticed I had a major power loss in the engine and took me FOREVER to track down the problem. I tracked it down to 2 critical pieces components. The MAPS and Air Charge Sensor. After I changed them, I noticed the low end RPM power bobble was gone. Acceleration is well, AWESOME My fuel mileage went from 18mpg to almost 21mpg. The PO did a mod on the intake that was just . So now I'm trying to track down an intake system off a 5.2 ZJ to get rid of the top filter set up. At the moment its drawling in hot air off the top. And is in desperate need of a radiator. The top of the radiator keeps splitting and letting coolant out. Good news is Autozone dropped the price of the radiators.
Old Sep 24, 2010 | 04:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool! Sounds like you got the power loss problem. For the radiator, see if you have a radiator shop in your town. They may be able to weld up or fix what ever is leaking. Or maybe you just have a bad cap. As for the intake my guess would be junkyard would have tons. Even a Ram or V8 will work, they are all work the same.
Old Sep 24, 2010 | 05:27 PM
Az93DKota's Avatar
Az93DKota
I'm gonna order a new radiator that has the wide core. This radiator does not like AZ heat. I need better cooling.
I talked to a guy today that has an airbox off a Ram but can't tell if its gonna clear the hood once I drop it. Its a freebee and won't know if its mine for a few more days.
