I have a 1994 Dakota 5.2 Mark III having problems getting it to pass emission in Ga
Old Sep 29, 2010 | 01:56 PM
Johnd85's Avatar
Johnd85
Default I have a 1994 Dakota 5.2 Mark III having problems getting it to pass emission in Ga
I have check the EGR vavle, it's working. Well I had a shop look at it and they said the timing was off. I let some one diagnose the problem but I'll be fixing it.
I went to do the timing and I can't get the timing mark to hit top dead center it's either way over or way under.
Old Sep 29, 2010 | 02:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Well what is your exact problem? What isn't passing?
Old Sep 30, 2010 | 12:28 PM
Hahns5.2's Avatar
Hahns5.2
You can't change the timing on these engines...
Old Sep 30, 2010 | 12:32 PM
Ramingo's Avatar
Ramingo
It is very rare to have the timing off, unless the motor was taken apart. Are you getting any codes or its just not passing the exhaust emissions?
Old Oct 1, 2010 | 01:04 AM
fox's Avatar
fox
First of all timing is completly controlled by the PCM so if your timing is off you either got a faulty sensor, timing chain ( it would run very very poorly), or you pcm is bad.
But that aside what did you fail for? Visual? Functional? HC, CO, Nox?
Old Oct 1, 2010 | 10:16 AM
Johnd85's Avatar
Johnd85
it runs like a champ....it's not passing NOx gas which is exhaust. I've checked the egr and vacuum line's and am about to put a new catalytic converter on it. It's has around 1300 to 1800 ppm on the NOx and it needs to run between 800 and 900.
Old Oct 1, 2010 | 10:20 AM
Johnd85's Avatar
Johnd85
Where would the PCM be located?
Old Oct 1, 2010 | 10:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Under the hood on the passanger fenderwell.
Old Oct 1, 2010 | 11:06 AM
Ramingo's Avatar
Ramingo
I used to cheat the exhaust testing by adding VP or a strong Octane booster, and about the catalytic converter, I dont have one and still pass emissions.
Old Oct 1, 2010 | 07:17 PM
dobaroy's Avatar
dobaroy
Changing the Cat would not be a bad idea. Good luck with it.
