speedodmeter not working
Old Oct 4, 2010 | 10:01 PM
xtriad4321's Avatar
xtriad4321
Default speedodmeter not working
So i was driving back from home to college when my odometer was reaching 119,000 on my dodge dakota and my speedodmeter and odometer both stop working!?!! moneys tight anyone got a clue what it could be?
Old Oct 4, 2010 | 10:05 PM
gladiator's Avatar
gladiator
Check fuses 1st
rest of the gauges working?
warning lights in the panel working?
possible the connector on back side of gauges worked loose??
Old Oct 5, 2010 | 12:53 AM
Crazy4x4RT's Avatar
Crazy4x4RT
First what year is your truck? If it is 93-down it will be the cable. If 94-up the sensor or wires.
Old Oct 5, 2010 | 11:07 AM
xtriad4321's Avatar
xtriad4321
Its a 92 2wd the rest of my gauges do work its just the speedometer and mileage are not working
Old Oct 5, 2010 | 01:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It will most likely be your cable. Just replace it. Napa was $20 I think.
Old Oct 5, 2010 | 09:59 PM
xtriad4321's Avatar
xtriad4321
ok ill check it out thanks ill keep you update but today my odometer started working again
Old Oct 5, 2010 | 10:10 PM
Hahns5.2's Avatar
Hahns5.2
Leads me to believe it may be the gauge cluster itself is dying.
Old Oct 10, 2010 | 12:58 PM
xtriad4321's Avatar
xtriad4321
well replaced the cable and its still not working
Old Oct 10, 2010 | 05:35 PM
DakDaddy's Avatar
DakDaddy
Question
Mine isn't working either but it's a 95 and I've replaced the VSS to no avail. Haven't checked wire yet, but there is no speedo cable on a 95, right? I've got other things needed to be fixed up before I worry how fast I'm going though.
Old Oct 12, 2010 | 09:08 PM
DakDaddy's Avatar
DakDaddy
95 4wd has speedo wires not cable right?
