Headlight Problem
Old Oct 17, 2010 | 06:24 PM
Tiwtin's Avatar
Tiwtin
Default Headlight Problem
My headlights have been having problems ever since I bought the truck. Supposedly they are out of alignment or something and aren't bright enough. They only show about 10 feet in front of me and about 20 feet with my brights on. Any help on how to fix this?
Old Oct 17, 2010 | 07:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can adjust them. Check out the service manual for the direction on how to. If it is not bright enough check your power and ground feeds.
Old Oct 17, 2010 | 08:16 PM
Road Hammer's Avatar
Road Hammer
They are halogen bulbs, whenever they are "on" they use a little bit of the gas. If the bulbs are old (5+ yrs) I would start with new bulbs. The lenses are probably cloudy too, so use a polishing wheel/pad on your drill and some cut-polish compound and finish with a good wax. We just did this to my sons 99 Ram and the difference is amazing!
Old Oct 17, 2010 | 09:52 PM
Tiwtin's Avatar
Tiwtin
So just clean the outside of the headlamps?
Old Oct 17, 2010 | 11:17 PM
Tiwtin's Avatar
Tiwtin
I couldn't find out how to adjust them in the owners manual. I googled it though and Anwers.com said to take it to a dealership to get it fixed =\
Old Oct 17, 2010 | 11:33 PM
issakar's Avatar
issakar
You need to probably check in the Factory Service Manual. there is a link to a service manual in FAQ1 on the main 1st gen dakota forum. Should be a post a few above this one.
