Did something stupid, Need help!
Old Oct 20, 2010 | 07:21 PM
issakar's Avatar
issakar
Originally Posted by Den37
I don't know if this will help,but I had an 85 Olds Cutlass Ciera with the 2.8l V6.The water pump bushing and seal wore out,which looked and acted EXACTLY LIKE THAT!
Good point to add in Den. certainly not something to rule out. Getting under the truck and inspecting that lower radiator hose up to the engine would probably be my first inspection of it were me. Make sure the hose doesn't feel rotted or loose or anything.
Old Oct 20, 2010 | 07:57 PM
sammatthews2007's Avatar
sammatthews2007
Yeah. Make sure the torque on your water pump bolts are good. Since it's coming from such a large area, makes it seem like it's coming from a large component (water pump, reservoir or radiator). Since it's only coming on when the system's under pressure (not a constant leak), I'd say water pump.
The fact that it was spraying up onto the windshield makes it sound like the fan was blowing it back.
Old Oct 20, 2010 | 08:17 PM
Tiwtin's Avatar
Tiwtin
Where is the water pump located? Would I have to put it up on a lift to fix it?
Old Oct 20, 2010 | 08:25 PM
issakar's Avatar
issakar
Old Oct 20, 2010 | 08:33 PM
Tiwtin's Avatar
Tiwtin
I couldn't find it at first glance.
Old Oct 20, 2010 | 08:38 PM
issakar's Avatar
issakar
couldn't find what? the pump? look at the diagram. Its behind the fan, and it has a pulley mounted on it with it looks like 4 bolts. You have to remove the fan and a bunch of other stuff to get to it. hang tight and ill try and get you the stuff on how to do it. brb
Old Oct 20, 2010 | 08:46 PM
Tiwtin's Avatar
Tiwtin
Oh... So I do have to take **** apart lol. I do not have the tools to do that so I'll wait for my mechanic friends to do it xD
Old Oct 20, 2010 | 08:56 PM
issakar's Avatar
issakar
honestly man, it doesn't look like its TOO difficult to do. I'll try and get the procedures up for you. basically you take the fan assembly off, leave it all together (the fan and the viscous drive) remove tension on the belt to take it off, remove the pulley and remove the pump. obviously you have to remove hoses and drain the system and such (per the FSM) but it doesn't look super involved. Anyone else ever performed the job and wanna chip in on how it is to do?
Old Oct 20, 2010 | 09:11 PM
issakar's Avatar
issakar
Old Oct 20, 2010 | 09:19 PM
Tiwtin's Avatar
Tiwtin
Since Id have to do work anyways... Would I be able to make it so the pulley doesnt go on my AC? Or does it have to go on it? lol
