Dodge Dakota V8 and transmission swap
Old Oct 24, 2010 | 09:17 PM
boberety69's Avatar
boberety69
Default Dodge Dakota V8 and transmission swap
I have a 1993 Dodge Dakota LE with a 3.9L V6 and automatic transmission. I am swapping out the 3.9L V6 with a 5.2L V8. I was wondering if I could use the transmission from the V6 with the V8? Also, can I use the PCM from a manual in an automatic?
Old Oct 24, 2010 | 10:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes you can use the V6 transmission with the V8 but it wont last to long. Think of it Dodge didn't put it behind the V8's for a reason. So finding a V8 transmission (46rh) is your best bet unless you want to do it again on day. Do it right the first time.
No you can not use a manual PCM to control the Auto. The OD and TCC is controlled by the computer.
Old Oct 25, 2010 | 07:58 PM
boberety69's Avatar
boberety69
I talked to a transmission shop in my area and this is what hey said: a 1993 Dodge Durango 4x4 with a 5.2L A500 4 speed automatic overdrive transmission is available either standard or Heavy Duty.
The Heavy Duty Utility Package includes a heavy duty band, TransGo Reprogramming and Utility torque converter. your cost is $1690.00 exchange
The stock Package with torque converter is $1380.00 exchange
This is the transmission they recommended. Would the A500? Is this a good price for a rebuilt transmission or should I keep looking?
