Some random questions???
Old Oct 29, 2010 | 09:17 AM
4x4Dakota93's Avatar
4x4Dakota93
Default Some random questions???
1. How do i fix my seat belts? they dont retract unless i push them back in
2.how do i fix my side rear view mirror driver side? when im driving it just kinda loosely bounces around
3. where can i find a faceplate for my cd deck?
4.where can i find the interior door handle cover?
Old Oct 29, 2010 | 10:27 AM
melodytoinvent's Avatar
melodytoinvent
1. Same problem sometimes, especially passenger side..oddly enough. Dont know a fix. 2. Do you mean one of your side mirrors? Theres a post on how to tighten em somewhere. Someone'll post it for ya lol 3. A whole new deck man. Unless you know exact model and stuff and can find one on eBay or something but thats probably a stretch. 4. Junkyard.
Old Oct 29, 2010 | 10:41 AM
Crazy4x4RT's Avatar
Crazy4x4RT
First 2 you can find in the FAQ in this section.
3rd call up the manufacture of the radio.
4th Junkyard or www.ebay.com or www.craigslist.org
Old Oct 29, 2010 | 12:24 PM
4x4Dakota93
On number 3 I don't know why I said face plate, I meant the the plastic assembly around deck that holds it in place, don't know name, and on number 4 what is a proper search name for it? Cause I keep getting outside door handle covers on searches
Old Oct 29, 2010 | 01:56 PM
4x4Dakota93
One other thing, my dome light works when I open door, but when I close it and try rotating **** it don't work? What's not working?
Old Oct 29, 2010 | 05:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It may a bad switch or a wiring problem.
For the radio bracket you can buy them from most autparts stores. Even Walmart.
Old Oct 29, 2010 | 07:11 PM
4x4Dakota93
the mirror thats in faqs is that chrome one that sticks out, i have the regular mirror thats like flush with truck has no arm it hangs out on
Old Oct 29, 2010 | 09:03 PM
Applehugger's Avatar
Applehugger
For the seatbelts, I would recommend taking them out of the truck and cleaning them. To clean, after removing the belts, pull the belt out as far as it will go and hold it in place with a clamp. Then soak as much as you can fit in a bucket with a high concentration of degreaser (Purple Power is what I used.) I let them soak overnight and then rinse throughley the morning after. Make sure the belt is 100% dry before allowing it to retract, and make sure you don't get the mechanism itself wet. This has worked on several cars I've owned. If it doesn't, I'd just run to a junkyard and find a belt that does retract.
