Clutch Master and Slave Cylinder Assembly Questions
Hey there,
I need a clutch master and slave cylinder assembly for my '89 Dakota. But, I can't seem to find one anywhere! If my memory serves me right, won't an assembly for a '90 work for the '89? Or is it the '88 and '89 are interchangeable?
Does anyone have a part number for this part? I thought I found one on RockAuto a couple months ago listed with the part number PS0590, but it looks like that is for a '95-'96.
The slave cylinder on my assembly is shot and that's all I really need, but I know these come pre-bled and whatnot and I'm not sure if it's worth it to just replace the slave cylinder. I can find a slave cylinder for an '89, so if it is possible let me know how to do it!
Thanks in advance.
Alex
Thanks in advance.
Alex
you might be able to get a chevy hydraulic clutch line and use it. i'm not sure if it will work. i did manage on my truck to get a gm clutch hose to work with the master and slave cylinder. but it took a lot of patience to get it properly bled.
Try your local dealer. Or www.autozone.com or www.napaonline.com or www.oreillyauto.com Or An OEM site like www.Dodgeparts.com
For use try your local junkyard, www.ebay.com www.craigslist.org
