Tachometer Jumping Crazily
Old Nov 6, 2010 | 10:16 PM
oxygen454's Avatar
oxygen454
Im confused now, is she talking about the tack or the speedo? lol Either way it wont hurt her tranny.
Old Nov 7, 2010 | 02:06 AM
93formula's Avatar
93formula
I've seen this in a lot of civics too. Usually it's a sign the ignitor is going and 99 percent of the time a dist swap fixes it. Good luck
Old Nov 7, 2010 | 04:17 PM
clhend's Avatar
clhend
Originally Posted by Crazy4x4RT
If you saw who I was quoting, I quoted oxygen454, so my statement was to correct his statement. He stated that the Tach is cable driven. The Speedometer is cable driven not the Tach.
You are right. My apologies.
Hate vehicle problems. Thanks for your help.
Old Nov 12, 2010 | 08:36 PM
oxygen454's Avatar
oxygen454
My bad, I got the two confused. Crazy is correct. (as usual )
Would her 91 be similar to a 95? https://dodgeforum.com/forum/1st-gen...achometer.html
(mine does the same thing but is a 93)
Old Nov 12, 2010 | 08:51 PM
clhend's Avatar
clhend
SOLVED! It was the negative wire (the larger one) coming from the battery, and attached to the back of the power steering reservoir (pump?). It finally fell off. Of course, truck wouldn't start....just 'tick-tick-tick-tick' when trying to start.
Ended up reattaching the wire somewhere else (no nut to fit the original bolt).
Started right up, no more tach jumping.
Old Nov 12, 2010 | 08:54 PM
oxygen454's Avatar
oxygen454
Cool, good to know. I dont think I would have guessed that other than grounds can be a real pain in the butt. Thanks for the reply!
