Swap 98 44re into a 96 dakota
Old Nov 6, 2010 | 11:04 AM
canadian-dj's Avatar
canadian-dj
Default Swap 98 42re tranny into a 96 dakota
Hi I have a 96 dakota 4x4 3.9 with 44re tranny that died I pulled the tranny already and just need another one but was told that only a 96 will work because of some of the electronics being changed. I found a good low milage 44re from a 98 and it looks exactly the same except a slightly deeper pan and the one 3pin sensor is different (they are both 3 pin just different) can I just change the sensor? and what or how can I make this work it must be possible.
Old Nov 6, 2010 | 02:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The info we have is that 3.9 has the 42re. The 97-up 5.2 V8's have the 44re. The 44re will work but as far as the plugs/electronics, You may be able to swap it.
Old Nov 6, 2010 | 06:09 PM
canadian-dj
Yes my mistake I was somehow thinking 44 but I do have a 42RE and the 98 is a 42RE can this work
