is there a way to test the computer ????
Old Nov 10, 2010 | 04:45 PM
gstry's Avatar
gstry
Default is there a way to test the computer ????
is it possible to troubleshoot a computer (odbII) to find out if it's bad???
or when all else fails it's the computer???
1996 Dakota V6 auto
thanks
Glenn
Old Nov 10, 2010 | 05:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What is the problem? Is it completely dead? Or does it work partly? The only true way to test is a OBDII scanner. But if it is completely dead you can make sure you have the correct power at the input wires to the computer.
Old Nov 10, 2010 | 06:28 PM
gstry's Avatar
gstry
the plugs are wet from fuel there is spark and all sensors have been replaced except the MAP sensor I unplugged the MAP and it didn't help... it was running and now just turns over... I will see if I can get a scanner...
thanks
Glenn
Old Nov 10, 2010 | 11:00 PM
tmacdakota's Avatar
tmacdakota
A scanner/reader is your best bet if it's not setting/showing codes through the check engine light on the dash...the FAQ section explains how to display and decode the CEL codes.
