idle control valve not activating ?? :(
Old Nov 20, 2010 | 02:15 AM
betillo's Avatar
betillo
Default idle control valve not activating ?? :(
everything started when i was driving my 94 dodge Dakota 2wd 3.9l it suddenly started to loose power when i pressed the accelerator it started to loose power so i parked and the engine was idling bad and when i rev the engine it started to turn off and then i went ahead an checked th engine and it seemed to me that the idle control valve not worked because i could her the loud noise of air going into the engine. and so i went to buy the valve and it didn't work the loud noise was still there so i thought it would be the cable was bad because it did't activate i checked all the fuses and non of them were broken and from there i don't know what to do because it doesn't even turn on now it kind of wants to but it doesn't
Old Nov 20, 2010 | 09:49 AM
sammatthews2007's Avatar
sammatthews2007
Check the notorious splice. See the FAQ for more info on it.
Old Nov 20, 2010 | 12:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It could be anything. Check all vacuum lines, all wires. Check your fuel pressure. A bad IAC would only cause problems at idle and low pedal pressure.
