NP231 transfer case question
Old Nov 22, 2010 | 11:21 PM
99MPower's Avatar
99MPower
Default NP231 transfer case question
I have a 1995 Dakota with the 3.9L 5 speed, 4x4 with the np231 transfer case in it. It has some MASSIVE chain slop in it, and it sounds like its about to blow up.
I found another np231 transfer case from a 1994 Jeep wrangler 4.0L.
WILL THE JEEP np231 transfer case work?
Old Nov 23, 2010 | 12:34 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No it will not. Yours is a NP231D D is for Dodge. The Jeep will have a J at the end. It is not the same transfercase.
Old Nov 23, 2010 | 12:43 AM
99MPower's Avatar
99MPower
son of a bitch... any more information on finding one or a rebuild kit?
Old Nov 23, 2010 | 12:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
www.napaonline.com may have a rebuild kit. If not then http://www.drivetrain.com/
Old Nov 23, 2010 | 08:39 PM
totman's Avatar
totman
what noise does it make? I think I may have the same issue with mine.... ugh
Old Nov 24, 2010 | 06:00 PM
Dodge4lyfe's Avatar
Dodge4lyfe
you can use the jeep transfercase but will need to swap the input shafts...
Old Nov 25, 2010 | 10:15 PM
tmacdakota's Avatar
tmacdakota
The J t-fer cases are punk-a$$ junk...not worth it to swap the input shafts. Hit the bone yards for a rebuildable replacement or rebuild your own...unless it has a big exit wound.
Old Nov 26, 2010 | 07:55 PM
413maxwedge's Avatar
413maxwedge
I don't think that they are junk the one in my jeep works just fine has most likily seen more rocks than you. The 231 in my dakota works fine to,maybe the user sucks?Name:  goink.gif
Old Nov 26, 2010 | 08:57 PM
tmacdakota's Avatar
tmacdakota
It works fine cause it's in your Jeep...and at 52 years I've forgotten more rocks than your Jeep will ever see. Use the NP231-D in a dodge and you won't be disappointed. For the time/effort spent sourcing and swapping shafts, you can rebuild your Dodge t-case.
Old Nov 26, 2010 | 09:20 PM
shadowthedakota's Avatar
shadowthedakota
unless you already inspected it, chances are it already has a hole in it from the chain rotating. my cousin bought a durango with a bad transfer case and drove it for 3yrs with a huge hole in it before he took it in...needless to say, he'll never ignore us again when it come to sounds from his car..lol
