Saggy rear
Old Nov 23, 2010 | 08:26 PM
kturner's Avatar
kturner
Default Saggy rear
We've been driving the dakota off and on for a couple months, but today is the first time I've actually used it as a truck. Someone I know cut down part of a tree and I went to get it for firewood. The dakota is a 96 slt 2wd 3.9l with a toolbox in the bed. I was surprised at how much the rear of the truck dropped when I put the wood in. It really wasn't that much wood. It was probably a few inches below the side of the bed, and the toolbox means that only 6' or so of the bed had wood in it (toolbox was empty). Before I unloaded it, I measured from the bottom of the rear bumper to the ground and it was 9". After I unloaded the wood, it raised to 13" and after I drove it back to the driveway, it had settled at 16". Do these numbers sound about right? Any tips on improving?
Keith
Old Nov 23, 2010 | 08:38 PM
siggie30's Avatar
siggie30
A: The springs are 15 years old.
B: I do not recall the weight of a chord of wood, but it will stress the springs noted in A.
C: You can "add-a-leaf" to increase stiffness under load, but did it rub or sway?
D: It's a work truck, right!!!!
Old Nov 23, 2010 | 10:39 PM
VINCE 91's Avatar
VINCE 91
Check out TIMBREN.COM. I have installed these on many trucks, including mine. When the truck is empty, it sits and rides like stock, but when loaded, holds the weight and handles like a dream. I put 4200 poungs of gravel in my '91 D200, and it sagged pretty bad. I put the Timbrens on a month later and hauled 4100 pounds.It sat one inch above level in the rear and handled perfectly. They only take about 20 minutes to install, usually no drilling, just need a wrench. I don't have them on my Dakota yet, but will. I also had a 2500 pound camper on my '74 D100 with the Timbrens on it. I swear by them.
