I need an honest opinion
Old Nov 29, 2010 | 12:40 AM
thebudman84's Avatar
thebudman84
Default I need an honest opinion
ok so when my truck idle i hearing like a whining noise coming from the accesory pulleys but i dont really know how to check it since it only happens when running. Any info would be appreciatated. It almost sounds like a bearing or pulley going
Old Nov 29, 2010 | 12:49 AM
oxygen454's Avatar
oxygen454
I have sprayed WD40 on the pulleys. Might not be the best for the belt but it helped track down the culprit. Could be alternator, idler, steering pump, air conditioner etc...
Old Nov 29, 2010 | 12:52 AM
oxygen454's Avatar
oxygen454
You may have to take the belt off and spin the pulleys by hand if the spray does not work. Also wiggle up and down, in and out.
Old Nov 29, 2010 | 12:57 AM
thebudman84
cause it goes away and then comes back seemed like it was coming from the power steering pump area though
Old Nov 29, 2010 | 12:58 AM
thebudman84
but it makes the noise most when i come to a stand still or in park
Old Nov 29, 2010 | 10:00 AM
Soundguy's Avatar
Soundguy
I also have a slight noise from that same area at idle, not a whine but, more of a small rattle. I took the belt off and spun/checked the tensioner and idler pulleys, no wobble or play there. They spun freely and silent. Some have mentioned a stretched timing chain, but it runs too good to be that (just guessing here though.)
I read where you can take the whole belt off, run it for 30-60 secs. to see if it still does it. Haven't tried that yet.
You say a whining noise. It could possibly be just the belt. Mine had a little whine a couple of weeks ago and I sprayed some belt dressing on it....gone now.
Old Nov 29, 2010 | 11:06 AM
festerw's Avatar
festerw
FWIW belt dressing is not a good idea for serpentine belts it will gum up the grooves and the belt could jump off.
Old Nov 29, 2010 | 03:20 PM
misfitdakota_95's Avatar
misfitdakota_95
best way to locate a noise in your drive belt is to get a long screwdriver next to your ear and put it near all moving pulleys; that will help you pinpoint the noise. Just be extremely careful around the fan and other moving pulleys. Don't put the screwdriver on the pulley itself, just around it. That is what all of us auto technicians do when we're trying to isolate a noise.
Old Nov 30, 2010 | 01:35 PM
9652dakota's Avatar
9652dakota
i use heater hose myself. safer for the noggin if you make a booboo and slap the fan. a stethoscope is a great thing to have aswell.
Old Nov 30, 2010 | 03:45 PM
oxygen454's Avatar
oxygen454
I totally agree with the screw driver and heater hose. Good call.
