'93 Dakota V-8 injector issue
Old Dec 2, 2010 | 02:31 PM
tmtm's Avatar
tmtm
Default '93 Dakota V-8 injector issue
have been having intermittent issue with our Dakota, it has a miss sometimes that is horrible, check engine light comes on, it has only stored a code a couple times number 7 injector, but when you check it, the injector is fine, got it back to the shop today and voltage was fine to injectors,
we have taken it to a shop about 4 times now even different shops, intermittent problems can be a pita to catch
ideas?
thanks
Tom
Old Dec 2, 2010 | 02:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
This is common. I believe the issue is the wiring or computer. It will be the power splice that feeds to all injectors. Or the ground output from the computer. The code would be 27, injector miss.
Old Dec 2, 2010 | 03:42 PM
tmtm's Avatar
tmtm
thanks, yes 27 was one of the codes, now it has
12 - 27 -15- 55 in that order
thanks again
Tom
Old Dec 3, 2010 | 01:55 PM
Danton88's Avatar
Danton88
Im having the same problem with my 1992 5.2 but with numer three injector.
