93 4x4 lower control arm bushings
Old Jun 11, 2005 | 02:50 PM
DoubleDrum's Avatar
DoubleDrum
Default 93 4x4 lower control arm bushings
I'm having a very confusing time finding the correct lower control arm bushings for my 93 4x4 Dakota. The dealer says they are no longer available and NAPA is confused about the correct application (2x or 4x or both use same part number???) Can someone tell me the straight story on these bushing applications and mayby give me the part #'s. Thanks Scott
Old Jun 13, 2005 | 09:32 PM
alaskan155's Avatar
alaskan155
Default RE: 93 4x4 lower control arm bushings
go onto oriellies website and they will tell you the part#, MOOG is 1 of the aftermarket suppliers
hope this helps
for the upper/lower bushing(not balljoints) 2x4 and 4x4 are the same, the 2x uses a different lower arm, but that is because it is coil spring
