low heat from heater
Old Dec 8, 2010 | 02:53 PM
GeeWhiz's Avatar
GeeWhiz
Default low heat from heater
my 92 dakota has a problem with getting good heat from the heater. i let it warm up i get in and have no warm air coming out of the vents on any other speed than the lowest fan speed. if i turn every thing off and wait a few mins i get a burst of warm air and then it cools down again. ive tried flushing out the heater core and that didnt do anything other than make a mess. also the two hoses that go to the heater core, one is really hot and the other one stays cold. this things got me stumped.
edit: i also made sure i had coolant and i made sure to let any trapped air out
Old Dec 8, 2010 | 04:22 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The vent doors may not be working properly. Try checking the cables ect. The FAQ has the service manual which has a Heating section that will have all the info you will need.
Old Dec 8, 2010 | 04:46 PM
GeeWhiz's Avatar
GeeWhiz
thanks ill take a look at that
Old Dec 8, 2010 | 05:42 PM
Spennyman1's Avatar
Spennyman1
From: West Virginia, don't believe what you hear.....
Is there anyway to update the FAQ sections. They have a lot of dead links.
Old Dec 8, 2010 | 06:00 PM
swapdip's Avatar
swapdip
Also you may want to try flushing the heater core out again. My heater had almost the exact same problem, a blast of warm air followed by frigid cold, turns out my core was almost entirely clogged. I tried using a hose to clear out the gunk but not much improvement. Then I tried this:
http://www.youtube.com/watch?v=mMp82zLVxoU
And now my heater blasts like a furnace. Can't beat a cheap, easy repair!
Old Dec 9, 2010 | 01:26 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is updatable. Specifically what is not working? Thousands of links, its to hard to click on everyone every day to check if it is working!
Old Dec 9, 2010 | 06:44 AM
siggie30's Avatar
siggie30
Instead of "oven cleaner" you could mix up some lye (preferrably sodium hydroxide which is available as DRY red devil brand- do not use liquid style clog remover) in cold water (exothermic reaction and it will get very hot comparatively) and get better results plus it is cheaper.
Old Dec 9, 2010 | 11:24 AM
GeeWhiz's Avatar
GeeWhiz
thanks for the help guys. i did the compresed air thing from the video and got some nasty, chunky crap out of the heater core and now my heat is alot better. its still not as hot as my station wagon but it works and it warm.
Old Dec 9, 2010 | 11:58 AM
swapdip's Avatar
swapdip
Great! Yeah the stuff that came out of my heater core looked exactly like chocolate milkshake, both in color and consistency (but not in taste, haha). I ran a couple of cups of hot bleach through it and got even more out, flushed the hell out of it with a hose, and then let the bleach sit in it for 2 hours and got WAY more out. So yeah, the cleaner the better.
With your heater core circulating properly your engine should run cooler and smoother, and you can't beat a good working defroster!
Old Dec 9, 2010 | 11:06 PM
Spennyman1's Avatar
Spennyman1
AllPar (1st Gen Dakotas),1995 Dodge Dakota Factory Service Manual PDF
http://rapidshare.com/files/42291478..._DFSM.ZIP,1996 Dodge Dakota Facory Service Manual PDF
http://rapidshare.com/files/20546066...arlock/Warrior
http://www.geocities.com/MotorCity/D...rrior.html,Lil Red Express (1990- 1992 by LER industries, made after factory)
http://www.geocities.com/MotorCity/Downs/6071/mag.html
http://www.geocities.com/tomcat98.geo/ . Here some that doesn't work on page one. Hope this helps.
