Tranny leak
Old Dec 9, 2010 | 09:26 PM
russ29ny's Avatar
russ29ny
Default Tranny leak
I have a 1988 with a 3.9l. Went to warm up my truck and i have a really big leak of tranny fluid on my drive way. It is coming out of what i think is the Torque Converter cover. 'Above the oil pan'. Is there a gasket or a seal that would have gone bad that would have cause the leak?
Thanks in advance.
Old Dec 10, 2010 | 10:15 AM
russ29ny's Avatar
russ29ny
Still is leaking. I checked all the bolts,they are tight. Filler tube is tight. Is my tranny shot? Or is it a gasket or a seal. Any help would be appreciated. Thanks in advance
Old Dec 10, 2010 | 12:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It could be the input shaft seal.
Old Dec 10, 2010 | 12:46 PM
russ29ny's Avatar
russ29ny
Ok thanks. dropping the transmission this weekend. since its dropped should i check for anything else?
Thanks
