check engine code 35,,,85?
Old Dec 11, 2010 | 07:48 PM
declid's Avatar
declid
Default check engine code 35,,,85?
heyy guys , iam getting now a 12, 23 ,27, and 55 ,,, i think i was reading them wrong at first,thanks,, tom
Old Dec 12, 2010 | 02:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The list of codes is in the FAQ in this section. https://dodgeforum.com/forum/1st-gen...-96-codes.html
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
23** Intake air temp sensor signal outside acceptable range
27* Injector control circuit failure
55* End of error messages (If you get this only, no errors were found)
Try resetting your computer by unplugging the battery for a min. See what comes back.
