Oil everywhere...missing gasket?
I went to start up the newly rebuilt 5.9L engine and it kicked over fine, then I heard a squeak and oil started spewing from the oil filter. I took the filter off and noticed that the machine shop hadn't tightened down the oil filter adapter and hollow threaded center piece good enough. The filter was sealing fine. So needless to say, I have 5 quarts of oil on my garage floor but I killed the engine so no damage was done. I am wondering if there is supposed to be a gasket under the oil filter adapter? Or is this a metal on metal seal? I didn't see one called out in the FSM, but then again I didn't see much about it in the FSM.
on
1 Post
i do believe it is just a metal to metal seal. the edge of the oil filter should have a built in gasket to seal around the edges. what might of happened is maybe the filter cracked from being overtightened, or maybe it just needed to be tightened a bit more. look at the filter and inspect for cracks. if there are no cracks, you can put it on and just tighten it properly. or just buy a new one. theyre not that expensive..
