transmission issue
Old Dec 16, 2010 | 05:28 PM
thebudman84's Avatar
thebudman84
Default transmission issue
so i have a trans leak and cant really tell exactlly where it is but i know there alot of fluid where the crossmember is and by the starter any tips?
Old Dec 16, 2010 | 08:55 PM
declid's Avatar
declid
sounds like it could be a trans line , could have rubbed a hole in it,,,check and make sure they arent rubbing on something,, tom
Old Dec 16, 2010 | 09:01 PM
RockGuardedDak's Avatar
RockGuardedDak
most common to leak is the fill tube o-ring. clean around the fill tube and surrounding areas, take it for a drive around the block, get under it and you should be able to see if its coming from there or not. if not, and you have a tranny cooler installed, look into one of those lines being ruptured
Old Dec 16, 2010 | 09:03 PM
thebudman84
i just hope a gasket or seal didnt go im taking to a shop tomorrow
Old Dec 16, 2010 | 10:31 PM
mazda7475's Avatar
mazda7475
fluid leaks are hard to track down, if you can pressure clean the area then run the truck through the gears with the brake on (idle only) and check for fluid you might be able to narrow it down. if you clean it then drive it the fluid will spread everywhere.
isn't the cross member at the rear and the starter at the front of the tranny? sounds like a front tranny seal leak that's spreading to the back.
Old Dec 16, 2010 | 10:41 PM
thebudman84
ya i cycled throught he gears after i wiped it all down and nothing but as soon as i was driving i felt the tranny slippin bad
Old Dec 16, 2010 | 11:59 PM
mazda7475's Avatar
mazda7475
sorry guy sounds like a burnt tranny (dodge 4 speed autos are known for it).
before you do anything check the fluid level, you might get lucky and the level is low causing the slippage, if not try changing the fluid to solve the slippage problem. might as well start with the cheap solutions first.
Old Dec 17, 2010 | 12:27 AM
thebudman84
i know for a fact its low i threw 2 qts in checked the level and it was full when i got home it was dry on the stick so well see
Old Dec 17, 2010 | 01:27 AM
JDakota92's Avatar
JDakota92
If you change the fluid, Only do a drain and fill. DO NOT PRESSURE FLUSH! High mileage tranny + pressure flush = death to trans.
