Engine Knock when cold?
Old Feb 21, 2011 | 10:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Hopefully it is not to bad.
Old Feb 21, 2011 | 11:39 PM
oxygen454's Avatar
oxygen454
Here is the vid... the knock sounds like the right side and a higher pitched spinning noise on the left...
http://www.youtube.com/watch?v=S62gnhj4rb8
Old Feb 23, 2011 | 11:38 AM
siggie30's Avatar
siggie30
Sounds like the lifters are bleeding too much or starving. The knock sounds like a bearing going out. Just because the knock is coming from the top does not mean that the bearing is not going out (metal vibration causes noise at both ends). The engine needs to be pulled and rebuilt. My .02
Old Mar 5, 2011 | 10:20 PM
oxygen454's Avatar
oxygen454
Im not exactly sure where the sound is coming from yet. I have a pipe and a long screw driver so I am going to see if I can listen for the sound. I may also have a mechanic listen to the engine. Its fairly loud when cold...
