transfer case
If I remember right it will bolt up to the transmission just fine as long as it came off a Dodge truck. But the rear shaft has a larger and different spline count. It is also longer. The front may be longer too. So front and rear Custom driveshafts will be needed. I believe a few guys in the 2nd Gen Ram section did it, check with them. What ever info you find post up here.
http://www.drivetrain.com/parts_cata...ge.html#DAKOTA
Thanks man. to anyone else with t-case questions
I believe so. But that is a lot of work, do it right the first time. You can rebuild it your self, there are kits. Check out www.napaonline.com
