Linkage question
Old May 7, 2010 | 09:05 PM
1995dodgedakota's Avatar
1995dodgedakota
Default Linkage question
1995 wont stay in 4x4,linkage or something else??
Old May 7, 2010 | 09:20 PM
95_318SLT's Avatar
95_318SLT
What do you mean it won't stay in 4x4? Thats really not much to go by.
Old May 7, 2010 | 09:52 PM
Dodge4lyfe's Avatar
Dodge4lyfe
that or t-case could be shot...does it make any noise??
And 95_318, I think he means that when you put in in 4 HI that it engages but pops out unless you hold it. My new t-case was like that after I put it in. The cause is not that the linkage is worn out, but the adjustment bolt for the bottom rod either loosened up or fell out, causing the alignment of the linkage to shift. Check the FSM for the proper procedure to adjust the linkage. Once i followed it, mine shifted fine and stays in gear.
Old May 7, 2010 | 09:57 PM
95_318SLT's Avatar
95_318SLT
Oh, I know what he meant... I just wanted to hear him say it. I don't like vague descriptions of problems. A lack of info doesn't help anybody.
And the proper procedure for adjusting the linkage is:
1) Loosen the bolt on the linkage
2) Put the transfer case in 4x4 - The nut that holds the shifter plate to the transfer case takes a 9/16 wrench... use the wrench to turn the shifter plate to the 4x4 position after you loosen the linkage.
3) Slide the shifter into the 4x4 position
4) Tighten the bolt on the linkage
Should take 5 minutes. If that doesn't fix it, take out and inspect the detent plunger.
Old May 9, 2010 | 12:39 PM
1995dodgedakota
Default linkage
Where would I find some illustration or pics..not my cup o tea fixin cars..
Old May 9, 2010 | 01:37 PM
Auron's Avatar
Auron
a tea drinker 'ay go coffee
mine used to do that pull it down till you can pull it sidewaysthen pull it about 1/2 inch farther then put it back to 4 hi thats how i fixed my problem
Old May 9, 2010 | 02:18 PM
95_318SLT's Avatar
95_318SLT
Here you go...
TransferCaseShifter.jpg?t=1273428915
Step 1) Loosen the "Swivel Lock Bolt" so that the "Shift Rod" can slide free in the "Shift Rod Adjusting Swivel"
Step 2) Turn the "Transfer Case Range Lever" with a wrench (9/16) so that the transfer case is in the 4 hi range.
Step 3) Slide the shifter into the 4 hi position, and then move it forward (toward the 2wd position) just a bit (an 1/8 to a 1/4 inch)
Step 4) Tighten the "Swivel Lock Bolt"
You're done.
Old Jan 3, 2011 | 07:35 PM
becca66's Avatar
becca66
Default 4x4
Should it be in four low and is it the big bolt that hold shifter to plate
Old Jan 3, 2011 | 07:36 PM
becca66's Avatar
becca66
Default fsm
What is the fsm ty
Old Jan 3, 2011 | 08:08 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Factory Service Manual. It is downloadable from the stickies at the top of this section. A few posts above this one.
