Remote Door Locks
Old Jan 4, 2011 | 11:26 AM
bertbart's Avatar
bertbart
Default Please help Remote Door Locks
Hi every one Im new here I have a Pro Start remote starter anyways
Im installing this on my 1996 Dodge dakota
I no it has 5 wire reverse polarity but how the heck do you install to two relays. I ve tryed everything from all sites and no go
and help please drivers door has orange and violet and pink and violet black 2 wires and one Red in center
Passenger is orange and v pinkand v with orange and black and pink and black and red in the center
Old Jan 5, 2011 | 12:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a pic of how to place the wires into the harness. Under the dash just where the wires come out of the door is best. Also depending on your system you will need to wire up the coil wires, some use a negative trigger others use a positive. The green is the wires to the relay. The Red is where you cut.
Also I will move this to the 1st Generation Dakota Sub-Forum.
Old Jan 5, 2011 | 01:34 PM
bertbart's Avatar
bertbart
Default confuiesed
Sorry i tryed that i dont get it
Old Jan 5, 2011 | 01:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What exactly don't you get. Do you know how to read a wiring diagram? Tons of helpful sites just Google it.
Old Jan 6, 2011 | 09:43 AM
bertbart's Avatar
bertbart
Default tryed that
i put 87 and 30 as 12v all the time on the relay fuesd and put 87a on switch side and 85 at the remote out put and it blows a fuse evert time oh ya 86 the other side of the cut wire
Old Jan 6, 2011 | 04:40 PM
festerw's Avatar
festerw
Try this and you should only need to cut the wires under the dash on the drivers side it'll control both from there.
Old Jan 6, 2011 | 10:10 PM
bertbart's Avatar
bertbart
Default where
sorry what one do i cut and where do the other wires go it only shows two on the diagram and cut ill have four
Old Jan 7, 2011 | 03:15 AM
festerw's Avatar
festerw
OK how about this one
http://k.b5z.net/i/u/6000490/i/pdf_d..._POL_DLCKS.pdf
Old Jan 7, 2011 | 09:48 AM
bertbart's Avatar
bertbart
Default ill try that
but does that mean two relys per door
Old Jan 7, 2011 | 11:28 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No you don't need 2 per door. The door locks are tied into each other so you need 2 relays, 1 to unlock, 1 to lock.
