What is it?
Old Jan 8, 2011 | 05:20 PM
DAKOTAJIM's Avatar
DAKOTAJIM
Default What is it?
When you lift the hood on each side there are two little spring loaded screws with cables leading from them. The cables look kind of like a hood release cable in size and go into the body behind the headlights. These are located on the body part just above the grill on the far left and right side where the hood rests when closed. Mine are getting rusty and just wondering if its something that needs to be replaced.
Old Jan 8, 2011 | 05:46 PM
shadowthedakota's Avatar
shadowthedakota
headlight adjustment screws...they should have a "v" and "h" above them...took me a bit to figure out too.
Old Jan 8, 2011 | 06:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Correct!
A few of mine are busted by the headlight. I have seen tons of Dakotas like that too.
Old Jan 8, 2011 | 06:18 PM
shadowthedakota
what do i win? hopefully a 4x4 frame...*crosses fingers*...lol
Old Jan 8, 2011 | 09:11 PM
DAKOTAJIM's Avatar
DAKOTAJIM
Sorry no extra frames laying around but i really appreciate the help. I knew someone would know the answer because this is the best site on the web with the smartest members.
Old Jan 9, 2011 | 01:49 AM
JDakota92's Avatar
JDakota92
Mine are busted too. Maybe one day I'll try to figure a way to adjust them without the screws.
Old Jan 9, 2011 | 10:00 PM
89newbie's Avatar
89newbie
Mine were frozen and rusty also. To boot some numnuts had stripped the plastic adjuster out at the light. I wd-40 the nuts, if that is what we want to call them, I then alligned it all, till I got all but one working properly. My fix for that was position the lil plastic thinggie where it should have been on the light for proper adjustment and ran the nut screw so it was hitting at mid point. (Get ready for the dirty word), I superglued it in place since Numnuts had stripped the frame. After it all had set up I tried adjustment and all was good.
Old Jan 10, 2011 | 09:44 PM
Wishihadahonda's Avatar
Wishihadahonda
mine are FUBAR too and i really need to figure a fix and adjust my lights i cant see **** even with the highs on and i drive ALOT
Old Jan 11, 2011 | 08:59 AM
89newbie's Avatar
89newbie
READ MY FIX IT HAS BEEN WORKING. AT THIS POINT I HAVE ADDED hELPER SPRINGS, BLOCKS, RAISED THE FRONT, ALLIGNMENT AND STILL ABLE TO ADJUST LIGHTS, BUT i AM CAREFUL. I HAD TO ADJUST THEM WHEN THE TOOL BOXES ETC WERE ADDED ALSO.
