Need help please - weird engine pause
Old Jan 11, 2011 | 01:16 PM
90 Convertible's Avatar
90 Convertible
Default Need help please - weird engine pause
Hello,
I am new here and this is my first post. I have a 90 Convertible with 54K original miles on it.
My engine pauses briefly and without any set pattern. Usually it does this as I am backing out of the garage, or rolling up to a stop sign. If you have ever had a fuel pump go out, or a fuel filter clog - it's a lot like that only much briefer in duration. I feel certain it is electrical, but have no idea what is causing the stumble.
I have replaced the plugs, wires, distributor cap and rotor. The problem remains.
Does anyone have suggestions or ideas?
Thanks in advance.
Old Jan 11, 2011 | 06:01 PM
oxygen454's Avatar
oxygen454
What size engine?
Have you checked for vacuum leaks?
Coil?
Injectors?
Old Jan 11, 2011 | 06:36 PM
siggie30's Avatar
siggie30
X2 on injector pulse. Unless you have tbi, then I would assume a clogged vacuum port.
