Suspension is SHOT
Old Jan 12, 2011 | 06:30 PM
9652dakota's Avatar
9652dakota
i've had monroe (the yellow ones) on my 91 ranger for 5 years and they do excelent. i also had em on my 84 motnycarlo befor i got rid of it and it handled great.
Old Jan 12, 2011 | 07:51 PM
ne14t's Avatar
ne14t
I think the yellow monroes are the gasmatic line and are similar to that of Koni/Bilstein. And no they wont be garbage Monroe is OE equipment on a lot of vehicles and like I said its all owned by the Tenneco group so it wouldnt surprise me if the same plant that makes the Rancho's makes the Monroe's.
Old Jan 16, 2011 | 07:34 PM
daneek155's Avatar
daneek155
can someone put a picture on here how a rear leaf spring helper should look like installed????? i am putting mine on and want to make sure i get it right here is what it looks like nowName:  2011-01-16_18-54-54_588.jpg
Size:  54.2 KB the bottom one is the one i installed
Old Jan 16, 2011 | 08:18 PM
dalemoser's Avatar
dalemoser
air helper,bolt on kit,check it out.they have them for 2 and 4 wheel drive.
http://www.suspensionconnection.com
Old Jan 16, 2011 | 09:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it looks correct. Use C-Clamps to close up the space in between the leafs then tighten up the center bolt.
Old Jan 16, 2011 | 09:50 PM
daneek155's Avatar
daneek155
so there should be absoulutly no gaps in between the leaf springs, tight then up with the 2 u bolts tight?
Old Jan 16, 2011 | 09:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya should be no gaps. Once the center bolt is done then yes tighten up the U-Bolts with the Axle.
Old Jan 16, 2011 | 10:50 PM
JDakota92's Avatar
JDakota92
You can also get shocks that have coil-over load assist springs attached.
Old Jan 16, 2011 | 11:36 PM
daneek155's Avatar
daneek155
ok thanks alot....
