If a squeal doesn't change with engine revs, then it is probably????
Old Jan 18, 2011 | 07:53 PM
1stGenDak's Avatar
1stGenDak
Default If a squeal doesn't change with engine revs, then it is probably????
I am thinking the radiator fan clutch? It only squeals when it is cold (clutch would be released) and the sound doesn't really change with revs like a belt squeal would.
Can I just spray it with something, or does it need replacing?
Old Jan 18, 2011 | 07:55 PM
ne14t's Avatar
ne14t
Is it a belt just starting to slip or a totally different sound? The only noise I ever hear from the front of my truck besides the roar of the engine is some lifter chatter (common and not detrimental) and the click from the fan clutch.
Old Jan 18, 2011 | 08:51 PM
1stGenDak's Avatar
1stGenDak
I inspected the belt and it seems good. No cracking or damage to be seen.
Old Jan 18, 2011 | 11:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just try WD spray one pulley at a time. Then test it then spray another. Don't get any on the belt.
Old Jan 19, 2011 | 08:53 PM
mazda7475's Avatar
mazda7475
it's not a belt. if you increase the engine speed and squeal DOES NOT CHANGE it's not the belts. if the squeel lasts a long time i would look at the fan clutch. nothing you can do but replace it. do you live in the midwest U.S. or western Canada? been pretty cold there. i swapped in synthetic tranny fluid and solved the problem of a cold weather squeel' just an option.
Old Jan 19, 2011 | 10:29 PM
1stGenDak's Avatar
1stGenDak
I want to take it off, and tried for about 1 1/2 hrs to get the damn thing loose but I couldn't keep the water pump pulley from turning. I have no idea what the FSM is talking about by insert a screwdriver but that ish isn't working. I tried a rubber strap wrench and it slipped on the pulley. I tried cranking down on the belt tensioner and the belt was slipping. I am going to buy a bigger wrench tomorrow, some penetrating oil, and will clean the pulley and strap wrench and see where that gets me.
Zac
