lift and tires
Old Jan 20, 2011 | 02:18 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by Senate427
How does the comfort of the rear feel like if you hit a pot hole does the back of your truck sway? And how many leaf springs do you have on the rear?
The rear is stiff, but I love it! It's a truck not a Cadillac. No sway from the rear, the front has some but not much.
Originally Posted by dalemoser
are they just stock,leaf springs,no blocks?leafs under or over the axle tubes? glad to hear can use stock wheels,i have aftermarket wheels,with a good offset,but dont care to use them because off wearing things out quicker,but probably will,just because of the look of the stance.
I have the Dakota stock Top leaf and the 3 lower leafs are the Ram 2500. 4 leafs with the overload spring below.
The offset wheels will not wear things out as much as lifts/larger tires do. I would just use them since you got them.
