Pitman arm size of bolt
Recently picked up a 1995 Dodge Dakota Sport 4x4.Needs a new pitman arm,was wondering what size nut that holds it on. 1 5/16" ? 33mm ? Thanks for any info.Also both sides outer cv axles boots are ripped.Can just the boots be replaced or is it better to just replace the cv axles assemblies ?
Richiewis
Richiewis
i used 1and 1\4 to tighten mine to make sure it was tight (75ftlbs); after removing the nut with a 33mm socket to replace the pitman arm, the socket i think is still on the nut. can anyone say brain cramp!
stick to the 33mm.
as for as the axles go replace the boots, axles are expensive and once you have done the boots your an expert. it's a lot easer than it seems. somewhere on this forum i have the shortcut version. i replaced each boot about 4 times, you learn!
P.S. thanks for the next weather bomb South Carolina. i only got a 2x4.
stick to the 33mm.
