replacement transmission
Old Jan 21, 2011 | 10:13 PM
jas0n's Avatar
jas0n
Default replacement transmission
I found a deal on a 89 dakota, 4x4 w/Auto transmission. The poster says that it needs a new transmission. I was wondering which other models I can find a transmission from.
wikipedia says that these vehicles have the same transmission:
* 1989-2001 Dodge Ram pickup 150/1500 V6/V8(2WD)
* 1989-2003 Dodge Ram Van B150/B250 V6/V8
* 1989-2003 Dodge Dakota
* 1993-2004 Jeep Grand Cherokee I6
* 1996-1998 Jeep Grand Cherokee 5.2 V8
I was wondering if someone can shed some light on this.. I was able to find a transmission from a 91 cherokee for around 100 bucks..
anyone care to help me out?
-thanks
Old Jan 21, 2011 | 10:39 PM
bjr1a's Avatar
bjr1a
Trans must be out of a 4x4 with the same engine bolt pattern.......your trans should be the A500 because i do not recall the A518 being released until 90..biggest thing to look for is the electrical shift solenoid connector must be a 3 pin....the later 8 pin is incompatible.....those 3- pin units were phased out to my knowledge in 94.....
Brian
Old Jan 22, 2011 | 03:06 PM
jas0n's Avatar
jas0n
thank you very much for the reply. My knowledge only stems as far as ford, nissan, and a little Jeep.
I guess I should explain what the issue is.... He says the truck only moves when the you first start driving the truck. and once everything gets a chance to warm up the truck will start moving, He also said the truck has been sitting for a few years..
He says that he thinks its the bands in the transmission but to me and a few friends it sounds like a fluid problem, either low or dirty fluid, or a problem with the TC.
I think for the price I would be paying I could live with throwing a transmission in there, but if I can avoid it, a sweet deal would be even sweeter.
Old Jan 23, 2011 | 09:41 AM
dobaroy's Avatar
dobaroy
If you decide to buy the truck, first thing I would do is bring it home and change the fluid and filter, and then try it. Good luck with it.
Old Jan 23, 2011 | 01:17 PM
bjr1a's Avatar
bjr1a
When it stops moving, you could check fluid in neutral and if it shows considerably overfull it definetly is a restricted filter.....when pump cant pull fluid through it will show high on the stick...
Brian
Old Jan 24, 2011 | 03:30 AM
jas0n's Avatar
jas0n
doesnt matter now, i was going to get it yesterday but the guy let me know 3 hours before I was going up to get it that he decided he wanted 400 instead of 250.. we had already made a deal and he broke the deal.. oh well...
I looked at his ad again and he added to the description that the trans pump needed to be replaced.
Old Jan 24, 2011 | 01:59 PM
RockGuardedDak's Avatar
RockGuardedDak
even tho its a high risk, for all you know, you could pay the 400 for it, change the fluid and filter, and it will be fine. but again, its a high risk when it comes to transmissions
