Turn signals not working on 1992 Dodge Dakota
Old Feb 8, 2011 | 06:45 PM
ColoradoDodgeDakota's Avatar
ColoradoDodgeDakota
Default Turn signals not working on 1992 Dodge Dakota
1992 Dodge Dakota V8
All of my turn signals suddenly stopped working a couple of days ago. Prior to that, they had been flashing much more rapidly than I ever remembered before. Last night, I checked the hazards and all other lights on the truck (brake lights, back-up lights, tail lights, etc.), all of which appeared to be working just fine. Any thoughts??
Old Feb 8, 2011 | 08:32 PM
Crazy4x4RT's Avatar
Crazy4x4RT
May be the switch or power or ground issues. I will move this to the 1st Generation Dakota sub forum.
Old Feb 8, 2011 | 11:57 PM
oxygen454's Avatar
oxygen454
Im thinking bad wiring, damaged bulb or socket, or relay. Doubt it is the relay tho.
Old Feb 9, 2011 | 01:14 AM
festerw's Avatar
festerw
Pull the flashers under the dash and switch them around.
Old Feb 16, 2011 | 04:59 PM
ColoradoDodgeDakota
Default Replaced flasher and my turn signals are all working again!
I replaced the flasher for my turn signals and they're all working again...thank you to those who replied with suggestions.
Old Feb 16, 2011 | 09:20 PM
oxygen454's Avatar
oxygen454
On second thought, maybe it was the flasher relay
Old Nov 19, 2014 | 11:39 AM
1992 Dodge Dakota 3.9 2wd Ext Cab's Avatar
Default my turn signals stopped working flasher work
so i replaced flasher still not working any ideas
my wipers not working ?
my blower not working no a/c ?
if anyone can give me ideas it wud be helpful .
thanks
Old Nov 19, 2014 | 02:46 PM
RalphP's Avatar
RalphP
1992 Dodge Dakota 3.9 2wd Ext Cab - This would be a good time to grab the factory service manual and find out what's in common to all those circuits.
My FIRST guess, however, would be the ignition switch (the switch itself, not the lock cylinder!)
Do notice that's a GUESS - it could be as simple as a blown fuse (I'd be checking ALL the fuses before I bought an ignition switch, though!)
For my 1988, with similar but not identical wiring, the common point is the ignition switch. Fuse 10 is for the flahser, fuse 11 is for the windshield wiper, and the radio (fuse 8) is on that same wire from the switch. Backup lights (fuse 2) and heater or A/C blower (fuse 4) are on another section of the ignition switch. With them is the power windows (fuse 5) circuit. The gauges are off still another section.
One thing to check also is to rock the switch carefully (usually with the motor off!) and seeing if the wiper, blower, and flasher will start up in certain positions.
But yah, grab the wiring diagrams out of the factory service manual and start chasing the electricity around.
RwP
