Old Feb 10, 2011 | 01:46 AM
ghostrider76's Avatar
ghostrider76
Default ?
i have 1995 ram 1500 with a v6 3.9 magnum the motor is shot so i got a 1994 dakota 3.9 magnum the question i have is my 1500 is a 5 speed the motor i got is from a automatic dakota will this motor work with my 5speed
Old Feb 10, 2011 | 02:33 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it will work. Just use the Rams flywheel ect. I will move this to the 1st Generation Dakota Sub-Forum.
Old Feb 10, 2011 | 01:50 PM
ghostrider76
Default thank you
i thought it would but a friend of mine was telling me somthing about the tranny and the motor. that the motor must have a indention for the tranny to slide in or something like that. not the drive shaft.anyway thanks for the info
Old Mar 3, 2011 | 11:55 PM
lowgear351's Avatar
lowgear351
you will need to put a poilt bearing into the crank shaft if you are going from auto to standred trans.
The crank should be the same .
