what to fix? code 34
Old Feb 12, 2011 | 01:43 PM
blown4_6's Avatar
blown4_6
Question what to fix? code 34
I have a 1996 dodge dakota 4x4 5.2L V8. My check engine light comes on all the time when i first start driving it. I read with an obd II scanner and it just says multiple cylinder misfire.... i just cycled the key and the code comes up 34. I dont know what to change or where its located.
Old Feb 12, 2011 | 05:01 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What is the problem? Is it missing?
Old Feb 12, 2011 | 08:33 PM
blown4_6's Avatar
blown4_6
i guess. the scanner says so. cant really feel or hear it though. I replaced the plugs, wires, coil, cap, rotor, cam sensor, crank sensor. I just wondered what was the solution to code 34.
Old Feb 12, 2011 | 09:23 PM
oxygen454's Avatar
oxygen454
Code 34: An open or shorted condition detected in the speed control vaccum or vent solenoid circuits. *
or
MUX speed control switch below rated volts.
Not sure if this applies directly to our trucks? I found this from Dakota Trouble Codes... so it should be related?
Old Feb 13, 2011 | 05:50 PM
blown4_6's Avatar
blown4_6
yea, I read that too. just dont know exactly what it means or how to fix it.
Old Feb 13, 2011 | 06:21 PM
oxygen454's Avatar
oxygen454
speed control vacuum is your cruise control. Do you have any lights on your dash?
Not sure what MUX is or stands for?
Old Feb 13, 2011 | 06:27 PM
oxygen454's Avatar
oxygen454
Here is another great writeup on code 34... HERE
Old Feb 13, 2011 | 10:28 PM
DAKOTAJIM's Avatar
DAKOTAJIM
Thanks oxygen 454 for that link it explaines why my truck is throwing that 34 code when i don't have cruise control.
