Wind/Rain Coming Through Door Seal on 1995 Dakota
Old Feb 12, 2011 | 05:32 PM
osugrad2008's Avatar
osugrad2008
Default Wind/Rain Coming Through Door Seal on 1995 Dakota
I have a 1995 Dodge Dakota 4X4 extended cab. The drivers side door has water coming in around the door seal above the window. While driving down the road there is a continuous whistle while driving down the road due to air coming in at the top. While driving down the road I can reach up and pull the top of the door in a little and made the noise stop. Does the door need adjuster or does the door jamb seal need replaced?
Old Feb 12, 2011 | 06:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Probably the seal needs to be replaced. www.jcw.com or http://www.steelerubber.com/
I will move this to the 1st Generation Dakota sub-forum.
Old Feb 12, 2011 | 06:03 PM
festerw's Avatar
festerw
Check the door hinges for play also.
Old Feb 12, 2011 | 09:01 PM
osugrad2008
Can the latches be adjusted to close a little tighter?
Old Feb 13, 2011 | 01:56 AM
shadowthedakota's Avatar
shadowthedakota
yes they can, but it might make it harder to close the door properly...
