93 Dakota Motor HOT - Heater Blows ICE
Old Feb 23, 2011 | 06:15 PM
MDThomas26's Avatar
MDThomas26
Default 93 Dakota Motor HOT - Heater Blows ICE
My 1993 Dakota with the 318 in it just began heating up VERY quickly and was pegged as I was shutting it down. However, the strange thing is, the heater is actually blowing ice cold air out.
Thermostat? What else could cause this?
Thanks.
Old Feb 23, 2011 | 06:41 PM
crazzywolfie's Avatar
crazzywolfie
sounds like your rad fluid level might be low.
Old Feb 23, 2011 | 07:46 PM
MoparMan1991's Avatar
MoparMan1991
Yeah id check the fluid first as that is the cheapest, then id check the thermostat, and then if that doesnt fix it id check the heater core.
Old Feb 23, 2011 | 08:38 PM
buick's Avatar
buick
My Dak was doing the same thing.
First, check fluid level.
Second, replace thermostat.
Third, disconnect hoses to heater core into firewall. Hold a bucket under one fitting, blast the other with the air compressor. Heater core might be clogged up, and a little air can help force the chunks out. Hook everything back up and refill fluids.
Fourth, check water pump.
Old Feb 23, 2011 | 11:11 PM
MDThomas26's Avatar
MDThomas26
thanks everyone!!
Old Feb 23, 2011 | 11:43 PM
dalemoser's Avatar
dalemoser
first guess,check fluid level,if out of fluid,fill it back up,start it,let it run just sittin,n watch the bottom of the front of the motor.water pump
Old Feb 24, 2011 | 12:20 AM
oxygen454's Avatar
oxygen454
I agree with the fluids and the thermostat. Im also thinking you may have a blockage. If the fluid is up and the thermostat is opening, you will need a good flush.
