timing chain on a 3.9L
Old Mar 11, 2011 | 05:22 PM
mazda7475's Avatar
mazda7475
simple - make sure your rotor button is aligned (at least close) to the no. 1 cylinder fire. then put the gears on so the dimples match, there easy to see. nothing to it.
i rebuilt a slant 6 dodge in the early 80`s. there was no distributor in it when i aligned the the timing chain. i checked and the piston was TDC. the thing i did not account for was weather it was exhaust or intake that was open. i had put the valve covers on to make it look pretty to the teacher. it would not start and i figured out the problem. i simply rotated the distributor 180 degrees.
Old Mar 12, 2011 | 12:26 AM
evintho's Avatar
evintho
Cool
Originally Posted by Soundguy
$80? Where did you get it? Did the gaskets and seal come with the kit?
$47.84 shipped to your door from Rockauto.com
Timing set is Cloyes and gasket set is FelPro. Type in 48401844003640 in the 'How did you hear about us?' box for the 5% discount. I did the timing set on my '95 3.9L a few months ago. I buy from RockAuto all the time 'cause they have quality parts at unbeatable prices and the shipping is very reasonable.
Old Mar 12, 2011 | 05:24 PM
totman's Avatar
totman
I bought the same set for under 60. I can't wait to get it installed
Old Mar 13, 2011 | 12:22 PM
thager's Avatar
thager
got it all done i just have to get a timing light on it to set the timing, im up in canada, i didnt want to wait for shipping and we seem to pay more for stuff here.
Old Mar 13, 2011 | 12:27 PM
Soundguy's Avatar
Soundguy
Correct me if I'm wrong but, I don't believe you "set" the timing on these trucks in this model year. The computer takes care of this.
Old Mar 13, 2011 | 12:30 PM
Soundguy's Avatar
Soundguy
Thanks man. There are several different timing set options though. I'm not sure which one to choose. I'd definitely like to go with a double chain/sprocket though. Should I also get a new tensioner?
Old Mar 14, 2011 | 11:50 PM
garyjrsonny's Avatar
garyjrsonny
your not wrong, you dont use a timing light to set timing.
Old Mar 15, 2011 | 12:57 PM
thager's Avatar
thager
well its at a shop now to figure it out, my 3.9 didnt have a tensioner on the timing chain,
i found my invoice and the timing set was $62 and the gasket set was $12.50
Old Mar 19, 2011 | 10:26 PM
thager's Avatar
thager
well i got it back , they caid the dist was out by 25 deg, so they fixed that and got it running ut they had it hooked up to a fuel pressure guage and when it was running the pressure slowly dropped, so i drove it home and changed the fuel pump and its been running great now.
Old Sep 6, 2011 | 04:07 AM
scrappy2686's Avatar
scrappy2686
ive just always lined up teh dots then played with teh distributor when cranked to turn and play. i like a little advance from time to time'
