93 dodge dakota
hey i got a 93 dodge dakota with roughly 165 thousand. i know it needs some exaughst work dun to it but its making a poping sound every once and a while some one said it was a coil causing it could it also be where the exaughst isnt alowing enough back preasure? i will know more tomorrow as i will have it home and can take a look at it..... also is there any place where i can get like replacment panels for the bed over the wheel wells??????
Welcome to DF. For replacement panels check the FAQ2 in this section just a few posts above this one. A few links to replacement body panels.
As for the exhaust, depending exactly what it is, it may be pre-detonation. Which is common better ignition parts as well as a colder range spark plugs like the Autolite 3923 is best and cheep.
"As for the exhaust, depending exactly what it is, it may be pre-detonation. Which is common better ignition parts as well as a colder range spark plugs like the Autolite 3923 is best and cheep."
when you mention ignition parts do u mean a coil?
okay thank you so much for your help this will give me a place to start looking... i drove it yester day and i forgot to mention that it seems to make the "poping" sound when your frist take off at lower rpm and it only does it once and a while
