no oil pressure on hills
I took the truck out for a test in the mountain foothills, and it did well, except towards the end when the wife noticed the oil light was on and then I saw the oil pressure gauge was pinned to 0. I parked the truck, took a look at the oil and transmission levels and they're all full.
My only guess is the steep hills, which we were going down one at the time, could cause the oil to slosh around and away from the oil pressure sensor. Could this be it? Or could there be a more serious problem lurking about? Could there have been any damage done since the pressure read zero, but the oil pan is full of oil?
-edit-
I'm looking into replacing the oil sender switch to eliminate this as a cause for the drop in oil pressure. I've been checking the FSM and my Haynes manual and I can't find any diagrams showing where the oil pressure sender is. Where is it located on the v6 engines?
-edit-
It is located near the rear of the engine to the left of the distributer. Look at the part on www.autozone.com to see what is looks like.
Do you think it's a sensor glitch because of the hills or could the oil have indeed sloshed and emptied out of the engine and could there be damage?
-edit-
Engine cooled down enough and I took another look. Is the sender unit between the EGR and the distributor facing downward?
I'm obviously going to need a deep socket to get to it. Does anyone know what size it is? (I'll need to buy one, but don't want to make 3 trips to the store like I did with the subaru.)
