T-case question
T-case question
Hello all. New to this forum but a long time Dakota owner. I see alot of experience on this board but i might be a little off base with my build. I was curious is anyone knew if there was an NP242 case out there with the proper spline count to hang off my trans. I found a ton of jeep guys swapping the 231 and 242 back and fourth but i seem to remember a spline difference from when i blew up the last case. Thank you in advance for any information.
Jonathan
Jonathan
I don't know of one that would come that way, but you can swap input shafts with your np231. I did that on my truck a year and a half ago. The bigger problem you'll run into with the jeep np242, though, is the output shaft is a smaller diameter, so you'll need to put a new slip yoke on the driveshaft and possibly lenthen the driveshaft.
https://dodgeforum.com/forum/1st-gen...w-parts-d.html
