need some help
Old Mar 26, 2011 | 02:52 AM
89dakota318's Avatar
89dakota318
Default need some help
On my 89 484 I have a clunk that I can't figurout. I replaced all balljoints tierods pitman arm idler arm and upper controll arm bushings and also shockes it didn't get anybetter
Old Mar 26, 2011 | 08:44 AM
siggie30's Avatar
siggie30
Broken frame support?
Old Mar 26, 2011 | 04:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Something is bad or broken. Only you can find it, since we can't see it. Get under the truck and move thing around. If you have to take it to a shop that does free test drives, and see what they think.
Old Mar 26, 2011 | 08:41 PM
shadowthedakota's Avatar
shadowthedakota
could be a bad cv joint...
Old Mar 26, 2011 | 11:34 PM
garyjrsonny's Avatar
garyjrsonny
lower control arm bushings maybe?
Old Mar 27, 2011 | 02:42 AM
89dakota318
It will only do it when I am reversing and turining the wheel at the same time, frame has zero rust and no cracks cv shafts are nolonger in at so I will have to check the lower controll arm bushings
Old Mar 27, 2011 | 10:14 AM
Crazy4x4RT's Avatar
Crazy4x4RT
If your CV's are not in it the wheel will fall off. The hub needs the spindle and nut in to hold it self together. You could of removed only the ends to keep it together.
But without CV's my guess is you wheel bearings/whee hubs are falling apart.
Old Mar 27, 2011 | 11:03 AM
JDakota92's Avatar
JDakota92
yeah, what he said
Old Mar 27, 2011 | 11:29 AM
89dakota318
I had an old set of cv that I spilt and put back into the bubs to keep preload... Hahaha good thinking tho
Old Mar 27, 2011 | 12:29 PM
festerw's Avatar
festerw
How about the sway bar links/bushings if it hasn't been removed.
